okay guys, did the carb swap, now what wire is for the fact. tach so i can hook it back up, it worked perfect so i wanna re-wire it back up. just need the wire to get to the coil.
the one that went to the neg side of the coil originally grey/yellow tracer maybe??? but if your using msd ignition, you'll also need a tach adapter for stock tach use
After converting to carb I never could get my stock tach to work again using the green/yellow wire. I even traced wire to back of guage to make sure it was the right one.
