overheated
So I over heated my 5.0L, pretty bad.. It started making a clatter noise after it got really how, and now it still clatters a little bit.. it sounds kinda like im low on oil.. If i overheat the car, will i burn up my oil? there is no puddle or anything, so i know its not leaking down the block or anything.. I wasnt driving when i did this, i was just trying to remove the air pockets from the cooling system and it got way too hot. Thanks
you should always have the heater running when doing such to purge the air as heater core is often the high point in the system.........you should be fine just don't do it again , what I do is when it hits 3/4 gauge I shut it off and let heat soak open the t-stat then after checking fluid level and letting it cool after a few minutes start it back up and watch gauge while monitoring heat output from heater
idk how hot it got.. and i didnt realize it was getting that hot, it started clattering and i shut it off.. it happens... im less worried about why i did it, and more worried about if thats something that will happen if it does get that hot..
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
