Pulled Codes...
Pulled Codes...
31 - EGR Valve Position/Pressure Feedback EGR Circuit Below Minimum Voltage. 0.24 volts (O,M,R)
I have my EGR disconnected and a block plate where it used to be lol...
18 - Spark Out (SPOUT) Circuit Open (R), Loss Of Ignition Diagnostic Module Input To PCM/SPOUT Circuit Grounded (M)
Im not 100% sure this is the correct code... but it blinked once, and it seemed like a longer then usual wait then it flashed 8 times...
41 - System Indicates Lean -passenger side(R), No o2 Sensor Switching Detected. always lean -passenger side(M)
yikes
91 - o2 Sensor Circuit Indicates Lean -driver side(R), No o2 Sensor Switching Detected. always lean -driver side(M), Shift Solenoid 1 Circuit Failure (O)
So where do you fellas think i should start?
yikes
code 18, make sure your spout is connected and not loose.
code 91/41 make sure you o2's are all the way in the bung and there is no exhaust leaks prior to reaching the o2's. if they are and you cant locate a leak, possible replacement of these o2's will fix your issue
side note of the o2's i took off the harness and cleaned the corrosion off the connectors and my 41/91 codes went away.
