EGR block off plate...
a little more searching and i found one...iam a little impatient.....here's the website if anyone is interested....
http://www.thedetailzone.com/Ford%20...j%20Access.htm
hey man, i went through this same search, finally found one. i think the block off plate by itself was between 9-10 dollars and the plug that goes into the sensor was an aditional 20 bucks. so i did it the "Poor Boys Performance" way. i took og the EGR and removed the gasket with it. i then took a pop can and cut it to the same size as the gasket!! then took some black silicone and mounted the pop can block off in conjunction with the gasket in place of the EGR and have no problems. and btw, you dont even need the sensor plug, the computer will compensate for it anyways, the car will run fine without it. Good Luck!!!! just thought id try to save you some money!!
Matt's 95 Stang
Oct 5, 2015 07:16 AM
