Clutch pedal real heavy
you can have a firewall adjuster or an adjustable cable they both do the same thing, a firewall adjuster is just more convieniet. I woundnt recommend the adjustable cable becuase they are weaker then OEM and with time the cable starts lossening up, especially a single nut application like above.
oh and adjusting the cable will do nothing for that heavy clutch pedal, adjusting the cable just shifts the point of engaging
ohhhhhh so i do have an aftermarket cable....guess ill have to switch that out. dont want any snapping cables.
so do you think if he went with the triple hook design and switch the fulcrum point that'd change the pedal effort?
the triple hook from UPR is simply to get around Steedas patent on its double hook design and the third hook should not be used, the hook closest to the firewall(when installed) should be used for stock cables and the second for adjustable cables
I thought you were talking about adjusting the actual fork itself, thereby somehow gaining more leverage, not adjusting the cable end. I have the Maximum Motorsports cable and adjuster set, and so far it's a great cable. +1 on the aftermarket clutch cables sucking ***. My King Cobra has ruined three aftermarket adjustable cables in 35,000 miles. The MM one comes highly reccommended, and although the jury is still out, so far it's working out well. When I get my motor, that King cobra is going to be beaten with a sledge hammer and melted in a furnace. LOL! I think a Centerforce will give a softer pedal feel.
i have centerforce DF and no that isnt my tranny but i've cleaned some of it and it will be sand blasted and painted when i remove it soon for a rebuild.
i just have to make sure im 100% health wise before i undertake removing the tranny. thats a lot of moving in a small space for me. if you didnt read about it i had a hernia fixed recently.
Really? When my cable was stiff, I replaced it and the clutch was less stiff. The more I adjusted it, the softer it became. Unless there's something wrong with my clutch and cable.
Boys I'm not so sure FivePointOhh knows what he is talking about! ...take that with a grain of salt....I've seen his mis-leading post
Sounds like a FRPP Cobra clutch or a clutch that's just about done!
tim, i do apologise for any misleading information i give and i do encourage if i am wrong for ANYONE to correct me if im wrong. i did put a disclaimer in earlier in this post this im not super familiar with.
as for other posts, there is some stuff im concrete about and some stuff is IMBO. im not a mechanic by trade, this is a hobby like most people in here.
also if you notice in here some of my posts are actual questions for more imput on something i dont quite understand. i do appreciate your imput as well and correction if im wrong. but dont bash me, correct me. im here to educate on what i know and get educated on what i dont know.
thank ahead of time.
