Electrical Problems
Old Nov 5, 2008 | 02:26 PM
EHG5150's Avatar
EHG5150
Angry Electrical Problems
I have an 89 LX 5.0 Ever since i got it there was a shortage problem with using the mirrors switch to move the mirror while the stereo was on because it would blow the fuse even though that switch was replaced. Then i noticed my turn signals and heater stopped working so i jiggle my ignition and press on my steering wheel to get that to work. Then when im driving and i have the heater or ac on if i put the clutch in my car will die.
If someone could give me some tips on what to do that would be great.
Old Nov 5, 2008 | 03:14 PM
stang8689's Avatar
stang8689
sounds like a bad ground i would start by testin ur grounds with a test light. Hook the light to a power source and touch the ground if it lights up its good
Old Nov 5, 2008 | 03:15 PM
mattdel's Avatar
mattdel
sad to say you probably won't find much help online. sounds like someone went to town on the wiring harness. best bet would be to either start tearin the dash apart and look for crossed/jumped wires, or pay someone to diag it. we can provide you with wiring diagrams to start your search, but sad to say **** like this takes hours and hours.
Old Nov 5, 2008 | 04:40 PM
EHG5150's Avatar
EHG5150
the thing is that i dont know much bout my car and i dont know where any of those grounds are.
Old Nov 5, 2008 | 06:40 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
there was RECALL on the ignition switch from FORD, that may be the issue thst needs replacing if you have to jiggle the switch to get things working
Old Nov 5, 2008 | 07:03 PM
MustangDen's Avatar
MustangDen
The key with electrical, of course is safety. Many problems as already noted can be grounding points no longer providing an ample ground. Also check for wear spots on insulation which unfortunately requires exposing alot of wire. But start with basic chassis grounds first. Get a repair manual with good diagrams to help you out. Lastly, if it's over your head take it to a shop. Electrical fires are never fun.
Old Nov 5, 2008 | 10:52 PM
EHG5150's Avatar
EHG5150
well where can i find a good repair manual?
Old Nov 6, 2008 | 07:25 AM
mjr46's Avatar
mjr46
like I said crawl under your dash and examine the electrical portion of the ignition switch , unplug connector and look for burnt pin connections
Old Nov 6, 2008 | 10:52 AM
EHG5150's Avatar
EHG5150
all right thanx
jma2
Jul 10, 2023 01:00 AM
ak98
Feb 18, 2023 08:36 AM
uberstang1
Sep 20, 2015 06:42 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
