not even 600 miles and....
i already have this loud tapping noise that at first was only here and there, you would hear it at idle rev it up and it would go away, now it is just constant....i just cant tell if it is coming from the top or bottom
if i was you. id pull valve covers off and check just to be sure. my buddy with a 68mustang (331 stroker) had a lil tapping noise. and his rocker actually came off while romping on it a week or 2 ago. it doesnt take long to pull off the valvecovers. so id check just to be sure. and if its a fresh 306. you may want to retorque it all down again anways.
Did it get worse immediately after you re-torqued? Or did it gradually get worse again like the original slow to worse to worst noises? If it instantly became 10x worse after you re-torqued perhaps it is the rockers even though you just re torqued.
post a video of the noise, but you need to check the valve adjustment by making sure each adjustment is set or checked while the lifter is on the base circle of the cam while checking each valve
Galactic
04-29-2019 02:56 PM
10-01-2015 09:11 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
