fuel pump problem
Old Nov 10, 2008 | 04:29 PM
1mean5.0's Avatar
1mean5.0
Default fuel pump problem
what would cause my fuel pump to run when the car is off it runs constantly i thought maybe a fuel pump relay
Old Nov 10, 2008 | 07:18 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
the ecm grounds the windings of the fp relay to start fp operation, could be a bad relay , but you need to see if the ecm is what is causing it to be commanded on ..if so , could be a bad ecm
Old Nov 10, 2008 | 10:51 PM
1mean5.0's Avatar
1mean5.0
i found the problem...bad relay under the seet, if i wiggle it around it stops. I will get a new one after work tomorrow
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
