MAF/Injector size difference
Old Nov 17, 2008 | 08:59 PM
WhiteLightning00's Avatar
WhiteLightning00
I'll have another roommate (in college) and a $2 raise per hour where I work...that's how I was hoping I could afford it later. I was hoping I could use the adjustable fuel pressure regulator and bump the fuel pressure up enough to compensate for the lower injectors. I won't be pushing a whole lot of boost. Do you think that will work with the adjustable fuel pressure? Thanks for your input.
Old Nov 17, 2008 | 09:31 PM
samseed101's Avatar
samseed101
Seriously, you do NOT want to **** around with twin turbo or any serious HP without a tune. And you sure the hell don't want to do it with a mismatched injector / MAF combo. Adjusting fuel pressure can only get you so far. That pretty much stops being useful when you get into any semi-decent numbers. This is going to cost you more money in the end if you don't do it right the first time. I'm not trying to be an ***... I'm trying to save you some time, money, and heartache.
Old Nov 17, 2008 | 09:36 PM
WhiteLightning00
I understand what you're saying and understand about the mismatched maf/injectors with turbos, I know that's not a good idea. I'm just looking for a maf that can get me by while my car is n/a right now, and after I get the turbos put on I will get a tune very shortly afterwards. I'm just wondering as long as my car is n/a should the maf work for right now?
Old Nov 17, 2008 | 10:10 PM
dudeboy's Avatar
dudeboy
Seriously, stop trying to 'get by' right NOW.
With twins, you will F things up in a heartbeat.
You will need a custom tune (via the J3 port) with the turbos. If you are going to tune it yourself, then NOW is the time to buy a tweecer/moates/PMS setup.
Learn how to use it while you are still n/a
Tweecer and Moates will allow you to run 'mismatched' MAF/Injector setups properly.
If you aren't going to tune it yourself, then buy the right parts for your current setup, or don't drive the car!!!!!!!!
From the content of your current posts though, you have a long ways to go before you will be comfortable with any of these tuners. (please don't take that as rude or condescending)
Stop driving the car with the MAF unplugged....
Old Nov 17, 2008 | 10:44 PM
luckythirteen13's Avatar
luckythirteen13
the fact that you keep asking despite everyone telling you not to do it tells me that you plan to do anyways and your just looking for reasurance that itll be ok to do. i wouldnt rely on fuel pressure to tune your car. the fuel pump can only handle so much fuel flow at high psi and high rpm. without a wideband your just guessing. why run lean and burn up your pistons or wash the rings by running rich when the only justification you have for doing so is to save $100 in the future. you bought the wrong size injector on a whim, it was a bad decision, dont make another bad decision because you want to make up for the first one
you said you got a good deal on those injectors well sell them at the same price or maybe a little higher price. use the money you make to buy the correct parts
Old Nov 17, 2008 | 11:19 PM
WhiteLightning00
Ya'll have pretty much convinced me....I've been looking at 42# injectors and mafs for them for the past hour and a half. Yea I was looking for that little bit of reassurance that it was gonna be ok, but I got the other part. Looks like I'm going to be selling some 38s and finding some 42s and matching maf. Thanks for the advice guys.
Tivo304
Aug 28, 2023 12:19 PM
Nov 10, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 06:25 PM
Sep 3, 2015 07:14 PM
