pcv valve
Old Nov 20, 2008 | 11:30 PM
5.0stang123's Avatar
5.0stang123
Default pcv valve
Where the hell is the pcv valve, i looked for it for like an hour and i still cant find it? Do i have to take stuff off to find it?
Old Nov 20, 2008 | 11:58 PM
primetime5.0's Avatar
primetime5.0
very back of the lower intake
Old Nov 21, 2008 | 12:00 AM
5.0stang123
Ya well how do i get too it? do i have to take all the intake off
Old Nov 21, 2008 | 12:09 AM
primetime5.0
nah you dont, its just below a bunch of crap back there
Old Nov 21, 2008 | 02:08 AM
luckythirteen13's Avatar
luckythirteen13
just reach your hand back there. there will probably be some wires/hoses in the general area but it helps to know what your looking for
Old Nov 21, 2008 | 09:59 AM
samseed101's Avatar
samseed101
A lot of times, I just reach back there and feel for it. It will be on the center of your lower intake and will have a large hose going to it. You can simply give it a tug and it should pop right out of the grommit.
This picture may help a bit. Now keep in mind that in this picture, my Upper Intake is actually off, so what you are seeing is the Lower Intake along with a 1" spacer on top of that. Now see the red circle with the arrow pointing to it? That's a rubber hose that is about 6 inches long (give or take.) That hose goes straight down to the PCV valve. So if you follow directly down that hose, in about 6 inches you'll run into the PCV and the grommit. As you can see, it's dead center in the rear.
Old Nov 21, 2008 | 10:01 AM
samseed101's Avatar
samseed101
LoL, looking at that picture also brings back memories. You can see my poor attempt at trying to hide / camo the nitrous solenoids. It actually worked for the most part. It semi-blended in so that unless someone know what they were looking at or had a clue about cars, they would just think that it was another line or object under the hood.
edited to add: and yes that's a breather on the valve cover. But PCV was disabled in my setup. It was easier to control blow by and easier to tune it that way
Old Nov 21, 2008 | 10:44 AM
JPJP's Avatar
JPJP
While you are in there servicing the PCV valve you might as well get a dental pick (or similar tool) and pull the PCV screen out (located under the PCV valve) and clean it up. I use gasoline to clean mine.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
