Where is the signal relay?
Old May 29, 2005 | 07:59 PM
JustinBHR's Avatar
JustinBHR
Default Where is the signal relay?
The turn signals quit working in the car. I changed the fuse, still not working. Can someone tell me where the relay is? The car is an '89. Thanks in advance.
Old May 29, 2005 | 10:35 PM
stanglx2002's Avatar
stanglx2002
Default RE: Where is the signal relay?
it could be the flasher thats under the drivers side dash
Old May 30, 2005 | 02:09 AM
stanging's Avatar
stanging
There are two flashers one for turn signals and one for the hazard lights. On some cars they are back to back on the fuse panel, but on my 93 one is on the fuse panel, it works the hazards and the other behind the glove box. To make sure, turn the hazards on and listen for the clicking. You can switch them out with each other to see if it is indeed the flasher that is bad.
Old May 30, 2005 | 02:26 AM
silver91gt's Avatar
silver91gt
did you check all the fuses, my flasher is behind where my stereo is.
Old May 30, 2005 | 03:12 AM
Black Snake's Avatar
Black Snake
Also check the switch itself, look at the wiring harness that plugs in to the back of the switch somtimes you might get a short and will cause your turn signals o quit working.
Old May 30, 2005 | 11:45 AM
stanglx2002
it maybe the mult function switch too
Old May 30, 2005 | 01:29 PM
JustinBHR's Avatar
JustinBHR
What does it look like? Under the dash I found a brown box. Could this be it?
Old May 30, 2005 | 02:14 PM
90GTRagtop's Avatar
90GTRagtop
The flasher is a small cylindrical device with two flat metal termals sticking out of one end to connect the wires to. I suspect your '89 is like my '90. If so, you can see one in the fuse panel that's just under the dash on the far left side. Unfortunately, this is the one for the 4-way flasher. The turn signal flasher is up in the dash just right of center. Kinda between the stereo area and the glove box.
You may also find this thread helpful https://mustangforums.com/m_461731/m...Csignal/tm.htm
I would suggest checking it out.
Old May 30, 2005 | 09:49 PM
tomabram's Avatar
tomabram
They are in different places for different years. In my 88 it was below the steering colum. Theres a small panel directly below the colum. Remove it and look to the left. Mine was attached to the dash right there. Round, light blue relay.
Old May 31, 2005 | 03:57 AM
luckythirteen13's Avatar
luckythirteen13
my flasher is behind the stereo but hangs down on the passanger side where i can see it. i just bought a flasher that has a clear case. i can see the insides working, pretty cool. check your flasher, they are cheap to replace
jwog666
Dec 27, 2021 08:09 PM
Seanam
Oct 4, 2015 10:15 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
jc409
Convertible Tech
Sep 24, 2015 03:38 PM
schecterplayer
Sep 23, 2015 08:38 AM
