advice on right cam for my 91 ??
RE: advice on right cam for my 91 ??
ok this should do thanks.my best 60'2.33 and 13.78 at 100mph. I found how to leave at higher rpm's on the nitto's but couldn't beat my best on street tires??
Have I just hit the best a stock motor can do?? I have equil length shortys, and full 2.5in exhaust,pullies, short belt (no smog but I do have a/c) 373 rear, cold air intake,front sway bar removed,skinnies up front and 275 60 15 out back.
[IMG][http://image40.webshots.com/41/6/8/4..._ph.jpg/image]
I have a b-303 cam, and it really pulls much harder than the stock cam, but from 4000 - 6000 rpm, my motor lost lots of bottem end power, till I advance my timing to 14 deg.
it is an alright cam, but after looking through a comp cams catalogue, I would have picked up an extreme energy series, or nitrous cam, but after you do it, you will probably get used to it and you will want more, so look what you plan on doing in the future too to help you pick the right cam.
although I have seen a 347 stroker with an 8psi supercharger and a b303 cam running in the low 11's.
junior04
09-28-2015 10:53 AM
