Finally got a video! Help diagnose problem...
heck for troubleshooting purposes penetrating oil will work fine, cause if it is the belt, it's gonna get replaced anyway and if it isn't a quick shot of brake clean while it runs will clean it all off, anyway just do as AODE stated and remove belt to see if noise goes away
I did run the engine with the belt off. The sound only comes when you accelerate now. The pedal it self not even close to WOT when you push it down, any ideas on that? I'll try and burp the coolant system but as of right now like I said everything is full and ready to go.The engine sounds great and I want to drive it, need to have it fixed by tomorrow or else it will have to wait a few weeks.
EDIT: Another update, now when I run the car I have white smoke coming out my exhaust pipes now. I'm guessing I'm burning off oil.
Sounds like it may be a dry rocker. Did you lubricate the rockers and pushrods during assembly? As for the white smoke I need more information. Did you purge the cooling system? How long has it run since the swap? Did you properly torque the heads with clean and lightly lubricated threads? Is the car a auto or manual?
Rockers where lubed up good. Head bolts properly torqued and set with lock tight. So on my list of things to do today I have to figure what is wrong with my pedal, burp the cooling system, and check the exhaust. I'll let you know if I make any progress.
Everything was installed properly. Right now I fixed the cooling problem. However, I have white smoke coming out of the exhaust. The car is cooling now though. I have an exhaust leak but that is not a big deal. Now, my exhaust has white smoke coming out the exhaust, coolant or oil?
