strong smell of gas after fillup
Old 12-02-2008, 08:56 PM
PUDman
PUDman's Avatar
Default strong smell of gas after fillup
after i fill up with gas and then park my car for awhile, the inside smells like i poured it all inside. it doesn't seem to smell while i'm driving, it's just after it sits awhile. this will go on for about 1/2 a tank, then it goes away. i've removed all the trim panels in the trunk and have checked around the filler neck while pumping, and see no leaks. the smell appears to be towards the rear. are all the gas lines on an 86 vert steel? i don't seem to be getting less gas mileage so i'm kinda ruling out a leak. like i said it only happens for the first half tank. are there any rubber hoses along the way i should check?
PUDman is offline
Old 12-02-2008, 09:16 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the seal for the sending unit/pump may be bad .....or the evap purge line is cracked
mjr46 is offline
Old 12-02-2008, 09:23 PM
dv3
dv3's Avatar
did you check the filler neck where it connects to the tank? ..you can usually see a "stain" from the gas leaking from the filler neck on the lip below the filler neck
dv3 is offline
Old 12-02-2008, 10:53 PM
PUDman
PUDman's Avatar
would i have to drop the tank to check all of the above suggestions? where is the evap purge line? i take it it's rubber
PUDman is offline
Old 12-02-2008, 11:17 PM
luckythirteen13
luckythirteen13's Avatar
i had the exact same problem once. turned out the filler neck rubber piece tore when i replaced my fuel pump.
the sending unit and fuel pump gaskets are on top so you would have to drop the tank to check those. the filler neck gasket is on the side and easily visible without dropping the tank.
where in so.cal. are you?
luckythirteen13 is offline
Old 12-03-2008, 08:00 AM
mjr46
mjr46's Avatar
I know you don't have a way to do this suggestion but if all else fails find a shop with a smoke machine, I have an adapter to screw on to fox tanks and I hook the smoke machine up to it and where ever the smoke appears will indicate the sorce of the leak
mjr46 is offline
Old 12-03-2008, 08:35 AM
PUDman
PUDman's Avatar
i like the smoke machine idea. thankx for all the input. luckythirteen13.. i'm in the
Crescenta Valley
PUDman is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
10-01-2015 05:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: strong smell of gas after fillup
