KOER KOEO Codes
KOER KOEO Codes
I finally ran my codes and after looking high and low I think I found a decent code table, but just to make sure can you let me know if I got these right?
Any help or suggetions would be very appreciated
KOEO
29-Insufficient speed sensor input (I believe my speedo cable got broken or melted when my x pipe got put on)
33-Problem with the EGR system (my x pipe's EGR port was sealed, so I just cut and sealed off the EGR until I can figure out what all to do to entirely delete the EGR
41-No Hego switch detected
54-Problem with the air charge temp sensor
91-Shift solendoid failure (nothing seems wrong with my shifting, I don't know what's up with this)
KOER
41-o2 sensor, my x pipe isn't sealed up properly on the flanges
91-Shift solenoid again
33-EGR again
11-?
KOEO
KOER
33-EGR again
11-?
41 - System Indicates Lean -passenger side(R), No o2 Sensor Switching Detected. always lean -passenger side(M)
91 - o2 Sensor Circuit Indicates Lean -driver side(R), No o2 Sensor Switching Detected. always lean -driver side(M)
54 - Intake Air Temperature/Air Charge Temperature Circuit Open (M,O,R)
For codes 41/91 (system lean) you may want to check this troubleshooting steps and this procedure for 54. LUK
lincolnshibuya
12-08-2015 04:37 PM
