Swapping to Gt40 stuff, Coupple Qs
Well, i finally bought a set of Gt40 heads, they have already been resurfaced and cleaned up and i got them for a pretty decent deal.
I still havent decided between the TFS stage 1, comp xe270 or xe274
but my main question is when i get the matching springs for the cam i chose, is it allright for me to use the stock rockers? because i really dont have a whole lot of cash lying around to throw a set of roller rockers on there.
Any opinions on the cam choice would be appreciated aswell.
Thanks,
Keith
Thanks,
Keith
Thanks,
Keith
Thanks,
Keith
well i dont plan on converting to stud mount to use those rockers... and my budget doesnt really have a spot for rockers at the moment
im kinda torn between the tfs stage 1, comp xe270 and xe274
any opinions?
any opinions?
Thanks,
Keith
Thanks,
Keith
1. Clean mill/shave the heads .020 of an inch $80
2.USE THE TFS-1 CAM, STOCK ROCKERS. $160
3.Set your timing to about 16* BEFORE Top Dead Center(O),. $0
4. Get an adjustable fuel pressure regulator and set the pressure to 39psi, and have fun!!!!! $75
5.Install and gap set of new copper spark plugs.$15
Expect a 40 hp gain, which is big through a T-5, than automatic.
260hp 325 tq at the crank id say.
thank you very much, the heads have been resurfaced on the combustion side, also it appears that some porting was done because there are remnants of blue dye in the ports.
I also have the BBK adjustable FPR and gauge. so im almost there
also, if applicable, set the fuel pressure with no vacuum line attached to the regulator.
Whats weird, my pressure stays the same rather or not vacuum is present ; ).
On the dyno, even at WOT,the pressure didn't flinch or fluctuate.
with the gt-40 intake if you have one, the vacuum routing will require a little tinkering, nothing you will not be able to handle.
Some ADJUSTABLE regulators have a provision for a vacuum line some do not(like mine).
Mine just adjust with a screw at top,no provision for the vac line that was on the old, so I capped it off.
When I wanted to remove vacuum, I removed a small vacuum line to the intake.
No change in pressure. But also note, my cam doesn't make much of any vacuum I believe,
this might explain why the pressure didn;t change with no vacuum ,
maybe someone can chime me in on that
http://cgi.ebay.com/ebaymotors/_Car-...4506.m20.l1116
Matt's 95 Stang
10-05-2015 07:16 AM
