One Peice HeadLights
This piece look familiar? That's the adjuster plate for your headlight and when you swapped to one pieces, I assume you took your old headlight out of it and replaced it with the new one piece setup.
The screws that run through that plate and clip to the headlight are the adjusters. On the backside of the plate, you should be able to see the end of the screw sticking out. You can turn it with a 1/4 drive ratchet and I think it was a 4.5mm socket, turning the screws moves the top or bottom of the light in or out depending on which way you turn them.
I hope I made sense =/ and if the screws are rounded off, use a set up small visegrips or pliers to turn them.
If you're one pieces don't clip into those adjusting plates then disregard everything I said haha.
Seanam
10-04-2015 10:15 AM
