headlight problem
Old Jun 8, 2005 | 02:03 AM
88_5.0's Avatar
88_5.0
Default headlight problem
I have a new headlight/foglight switch so i know that isn't the problem. My headlight switch will be on and all i have are parking lights. I hit the bright's and they work. What part do i need? Is it the entire wiper switch assembly or is it an internal switch?
Old Jun 8, 2005 | 02:41 AM
settled4automatic's Avatar
settled4automatic
Default RE: headlight problem
whole switch, its the only way you can get it. i did a "custom job" on my 87 when that happened.
1) take the switch out of the column (not too bad of a job)
2) find the harness that goes to your headlights
3) found end of harness in burnt pieces, with burnt wires. cut end of harness off, stripped wires back, matched headlight signal wire with 5V reference, then i just tied in a $.80 switch from radio shack and there's my headlights.
you'll need some extra wire to do that one, so that it doesn't have to sit up in the column or under the dash :P
yeah that's right, i'm cheap =}
Nurdyguy
Jan 20, 2025 04:38 PM
StalkerGT
Nov 28, 2015 03:09 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
