Nitrous ???
Nitrous ???
I have an 86 s/d mustang gt and i want to shoot nitrous. The performance parts i have are,Edalbrock intake manifold,MAC cold air intake,75 mm t,b and spacer,MAC headers,373 gears,I want to know what shot i should go with.I wanted to shoot a 50 shot. i want to know what shot you guys think i shoul go with .Thanks for your help
well i think that even though your block is stock, you should still have forged pistons. so id go ahead with a dry kit 100 shot. i mean your pistons would handle that. so im sure if your only wanting to go with 50, youd be just fine!
50 shot is a nice safe place to start especially if you don't have the money or time to build a new engine. Nice pretty safe kick in the pants. You can feel a 50 shot. Refreshing to see someone not asking " Will it be safe with 150 shot", lol
i installed the 150 dry kit never ran it at the track , And not really into the dry kit , There is no tunablity. This is how it works, its all about bottle pressure the bottle needs to be pretty full and 85 degrees f . When you hit the n20 it goes to a n20 regulator then to you fuel pump regulator and slamms the fuel reg shut. If you get the nso kit that comes with a upgraded fuel pump( this runs in line with your stock fuel pump) it boosts fuel pressure to 80 psi pushing more fuel through the injectors. There is a T off the n2o reg that can be changed for fuel pressure tuning, and a jet for the n20 to select 50 , 75, 100, 150 hp shots. The wet kit is the way to go then you can really tune the fuel jet and n2o jet after the TB.
I got my kit unopened off Craigslist for $280. I will up grade to the wet kit before I really run the car. I did take it out and lay into it a few times. It was good I ran a 100 shot.
I would need a fuel reg and a dyno to tune for the n20 set up. although I tried the timing at 10* and the car was a dog , moved it to 14* and it was good , I know , I know 14 bad on n2o but there was no ping or knock at all. Most of all the temp outside was 65 with a full bottle which means it was starved for n20 and rich with fuel
My 2 cent n2o is cheap power and fun, But N/A is the best by far IMO
