Installing Speedo Gear
Are there directions posted anywhere to install a speedo gear in an AODE? I have 4.10's and my speedo's something like 10 - 15mph off. I have the gear but just need a little guideance on installing it.
Any help is appreciated.
Thank you
Thank you
If it is anything like most of the others, you take out one bolt that holds it to the trans case. Pull the little clip off the cable that holds the gear on. Replace old gear with new gear, reinstall clip. Install newly calibrated cable into same hole it came from, tighten the bolt back up and you will be done. Took me less than 5 minutes to do mine.
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
