Q about testing EGR
Q about testing EGR
So i still have a code 34. closed circuit above range EVP sensor.
but i ran into other troubles.
i went ahead and checked my egr, and i read that i should apply 5 lb(?) (mg) to the egr and the car should almost die, well i applied 5 _ and the car barely stumbled for a sec and then held steady. This should mean my EGR is bad right? well when i pull the vacuum back off the Egr then the car dies? is this normal? Am i doing it right?
oh codes are 85, 34 KOEO
94,44,34 KOER
and the egr is hooked up when i ran the codes and i reset codes before i ran the check
94,44,34 KOER
I don't know, it shouldn't die when the valve is being shut, in fact it should go back to running smooth, I was just workng on an egr system for a mitsubishi eclipse this past week and egr is egr, you open it at idle and it runs rough and close it = restore smooth idle if it is in good working order, meaning the valve, so as long as your valve is functioning properly, it should operate as I suggested
So you think the egr could be bad with out throwing codes?
jwog666
12-27-2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GT350 S550 Tech
09-29-2015 03:29 PM
