A/C problem
Old Mar 4, 2009 | 02:30 PM
mastermic's Avatar
mastermic
Default A/C problem
Hi I have a 95 mustang Gt 5.0 litre and the A/C clutch is not kicking on. The fuses and relays are good. Wire at the compressor is connected. Tried filling with freon it wouldnt take much(still didnt kick on) Switch in the car seems to work what could it be?
Old Mar 4, 2009 | 03:31 PM
mastermic's Avatar
mastermic
Also the blower is blowing air just hot air since the clutch on the compressor is not turning.
Old Mar 4, 2009 | 03:42 PM
Portmaster's Avatar
Portmaster
Jump the wire at the low pressure switch and see if t runs. If Not then check for power and ground at the compressor. You really need to have a set of gauges to check the pressure in the system. Could be a number of things from a bad low pressure switch, low freon, bad AC clutch, Open in the wiring, etc, etc.
Old Mar 4, 2009 | 03:44 PM
mastermic's Avatar
mastermic
Is the low pressure switch the one on the back with the condensor
Old Mar 4, 2009 | 05:58 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
before even jumping he switch I'd check the a/c pressures to see if it's ;low on freon
Old Mar 4, 2009 | 07:42 PM
Portmaster's Avatar
Portmaster
It was just the first thing I thought of. In my mind I could see him standing beside the car with one of those AutoZone "Self charge kits" hahaha!!!!
Old Mar 4, 2009 | 08:02 PM
mjr46's Avatar
mjr46
honestly , I've never used one of those....lol, I always have used either an a/c machine or manifold gauges
Old Mar 4, 2009 | 08:14 PM
Portmaster's Avatar
Portmaster
I love my Bear Evac and Charge station. Just set it and head off to the bath room with the latest Issue of Hot Rod, lol
Old Mar 4, 2009 | 11:06 PM
mastermic's Avatar
mastermic
Found the problem shot some dye in it it was leaking all the freon oout from the inlet hose on the condensor, Thanks.
vargas
Jun 17, 2017 12:17 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
