temp problem
Old Mar 5, 2009 | 05:41 PM
malo012000's Avatar
malo012000
Default temp problem
I have a 94 gt and the radiator wont build any pressure and the car temp stays in the middle or a little higher also had cap off and seen some what looks like oil in water comes up to top and makes little rings in coolant but no water in oil ... Have put new cap with no change help please
Old Mar 5, 2009 | 07:12 PM
NoGo95GT's Avatar
NoGo95GT
Oil in the radiator is not a good sign. There's a good chance you have a blown head gasket. Before, dismantling the motor, I would run a compression test to make sure.
Old Mar 5, 2009 | 09:36 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
.....radiator won't build pressure??? as a liquid is heated, it expands and such done under pressure raises boiling point..........so is car overheating???
Old Mar 5, 2009 | 09:47 PM
malo012000's Avatar
malo012000
No the car has only got to the a in normal and will go back down to half... The oil maybe from the shop I went to, they picked up the old coolant jug and added water witch wasnt much at all
Old Mar 5, 2009 | 09:53 PM
mjr46's Avatar
mjr46
when the temp goes up that high are you in stop and go traffic or on the highway??
Old Mar 5, 2009 | 09:58 PM
malo012000's Avatar
malo012000
I am getting on it like leaving a light or just stepping on it
Old Mar 5, 2009 | 10:20 PM
mjr46's Avatar
mjr46
so while sittng at the light it's fine then as soon as you take off, you get on it and out of the blue it jumps up real quick??
Old Mar 5, 2009 | 10:32 PM
malo012000's Avatar
malo012000
Well yes but not like a wire short but just starts to rise and as soon as Im at the speed I want it goes back to half and stays or just a little lower ...I let it idle in the yard for 30 min and stayed at half
Old Mar 5, 2009 | 10:40 PM
mjr46's Avatar
mjr46
the gauge may be overly sensitive or it could have a faulty head gasket, but above all you need to verify your low and high speed function for the cooling fan operates as designed
Old Mar 5, 2009 | 10:43 PM
malo012000's Avatar
malo012000
how would I check the fan
