3.77 gears vs 3.55
Accurate enough for this topic. Original poster has a GT so it's a TracLok.
As long as both wheels are spinning the same direction during the test it will be fine.
Portmast would be correct if we are talking about an open differential and the opposite wheel was not taken into the calculation.
Even an open diff can be checked with either 2 revolutions of one tire or one revolution each tire vs the driveshaft.
I do agree with luck13. Not enough difference between 3.7 to 3.5 to warrant a gear swap.
If the rpms need a change, jump to 3.27 or 3.08's.
I've had 4 different gear sets,2.73,3.55,4.10 and now 3.73 in my 87 gt .In my opinion the 3.73 is perfect compromise of performance and fuel economy. There is some difference but not really enough in my opinion to change as it will cost unless you do it yourself.
I'm not advising on the MOST ACCURATE method of figuring out his gear ratio, just the easiest.
Your idea to the original poster to confirm the gears before setting out and swapping them is a good idea.
With the rear tires off the ground a 90% worn trac lok will still spin the opposite tire the same direction, the same amount.
I do not debating your method of counting teeth but one wheel revolution and counting the driveshaft rotations is good enough for figuring out your gear ratio for comparison.
No degree wheel required. 3 turns is 3.08's. 3 and 3/4 turns is 3.73's and so on.
Anyways, either method would work.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
