Drive shaft bolt size
Tommarow im installing my aluminum driveshaft. When i was under the car last week i noticed the bolt's where 12point(i think there called), that i dont have sockets for.
what size are they, and can a wrench work on them? or do i have to buy a special socket?
also do you think its possible to install the driveshaft without removing the H pipe?
id like to just rip the old one out, and slide the new one in, it will be a pain if i have to remove the mid-pipe. (doing this in a parking lot with the car on jackstands.)
thanks in advance.
thanks in advance.
yep just slide it in over the pipes, and for the bolts just get a metric 12mm 12 point socket... dont use nuttin else on them bolts besidz dat
nothing especialla,go for it
I have a socket set up just for these. It's a thin 12mm 12 poit impact socket on a pinned Impact universal. Take me about 20 seconds to get the driveshaft out of a Mustang. Mine has U bolts so I'm using a 9/16 wrench on those babies, lol. Yes it's possible to get the driveshaft out over the H pipe. If the wheels are on the ground it will come right out. On a lift where the rear is dangling it can be a little tougher. Juak it uo and put the jack stands under the axle tubes and let the weigh off the jack. That will give you plenty of clearance with long H pipes.
cool!
thank's portmaster!
I will run by Ace hardware on the way home from work and pick up a 12mm 12pt socket.
i normaly prop the car up by the k-member and the axle tubes, so i hope this will work out good.
hopefully this fixe's the vibe's im having above 65mph :/
thank's portmaster!
just got done swaping them out, drove the car around the building and it's smooth.
taking a quick break, then imma go test drive it and see if it fixed my vibration issues.
you guys where right, the new aluminum driveshaft is a bit harder to get around, i think its about half a inch bigger in diameter then the stocker.
aluminum driveshaft was 14.5lbs
stock was 23.5
That's a weight loss of around 9lbs!!!!!
i was expecting 5lbs, not 9.
i weighed it on my bathroom digital scale, so it could be off by a bit, but i weighed both of them twice, and back to back, so it should be pretty accurate.
stock was 23.5
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
Gary Ugarek
63
12-11-2015 02:01 PM
