my goals
my goals
i want to have a solid preforming 5.0 mustang that is still very street drivable, and corners decent and have it run mid to high 12's in the 1/4 will this list of part i have and or will be getting acomplish that goal
ported and polished and gasket matched e7 head
airgap intake manifold
holley 650cfm 4bbl carb
equal length shortys
upper and lower rear control arms
coilovers
adjustable shocks and struts
aluminum driveshaft
poly motormounts
every busshing in the suspention system replaced with poly
battery relocation
weld in subframe connectors
and an cowl induction hood
coilovers
aluminum driveshaft
poly motormounts
battery relocation
RE: my goals
i forgot to mention i already an full exaust system. and also forgot to put cam on the list, and the reason why im not going with afr's is they cost to much money for me, if i can get my hands on a set of junk yard gt40's ill go that way. but i would think 6-700 would cover an nice port and polish job on a set of e7's that will get close to the same preformace as afr's. im also not a big fan of gears but iv been considering them
RE: my goals
The best port and polish job in the world wont see the numbers that AFR's would give you, Ill tell you that much, and without gears, 12's will be VERY hard.. Not to mention you'll need a good slick....
RE: my goals
im not compleetly ruling out gears, im just not a big fan of them, and slicks i think go without mentioning, i think its pretty much imposible no matter how much hp you got to run a 12 on 60k mile street tires. btw id be happy with one 12.98 run preferibly 12.5 but id 12.98 would be fine with me as well
mungodrums
Suspension
02-09-2016 09:05 AM
