engine warm
Old Mar 15, 2009 | 12:14 AM
lx5.0's Avatar
lx5.0
Default engine warm
my car starts up fine i let it idle for like a min then i shut it off and try it again and it sounds like its going to start but it doesnt it just cranks after like 10-15 mins it will start again what could be causing this what should i look into i have fuel and spark, and it smells a lot like fuel thru intake mani
Old Mar 15, 2009 | 01:23 AM
jthorn9's Avatar
jthorn9
The Godfather
Faulty IAC valve
Clogged or Faulty PCV valve
Faulty Thermostat Sensor
Faulty Temperature Sensor
Fualty EGR valve or sensor
Any of the following going out will cause similar issues.
Old Mar 15, 2009 | 01:41 AM
lx5.0's Avatar
lx5.0
i have a new iac, deleted egr pcv valve is new also the temp sensor where is that located is it on the right side like in the bottom of the mani if it is that one did look real bad like it had a lot of junk stuck to it and i believe the thermostat sensor is the one on the other side that sits on a tube right
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
5.0 kevo
Sep 3, 2015 06:24 PM
