Breaking up bad above 2700rm
Sorry to Hijac the thread but mine is something similar and don't know all the codes!
111-Pass code??
165-?
536- Brake On/Off swithch so I replaced it, shouldn't cause it anyway! Checked the TPS sensor and is in range!
The coil is suspect. The secondary was on the low side @ 7.2k-ohms and haynes says bottom is 7.7k-ohms. We were close to 10m-ohms on the primary winding to case test. The coil wire is less than a foot long and it was a 4000 ohms. I don't exactly remember the coil's primary resistance but it was in spec.
Thanks!
111-Pass code??
165-?
Thanks!
May be fuel related. Did this just start happening or did it progress? If it has been slowly progressing it could be bad fuel injectors and a fuel pressure test will not show it. You need to run KOEO/KOER tests, check fuel pressure, and read the plugs.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
