fuel line question
Old Mar 31, 2009 | 11:30 AM
worm2500's Avatar
worm2500
Default fuel line question
i heard stock fuel lines are adequate up to 300hp. but what about the other sizes starting with -6AN up to -10AN. The reason i am asking is because i am building a motor thats going to be around 450 500hp will -6AN be enough or should i go with -8AN. this motor is also carberated
Old Mar 31, 2009 | 12:38 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
<--stock fuel lines and I am running 397 rwhp on a blower.
Old Mar 31, 2009 | 01:16 PM
Portmaster's Avatar
Portmaster
AN lines are measured in 16th's of an inch -8an= 8/16's=1/2 inch. I make it a rule of thumb that once the HP passes the 500hp mark 1/2inch or -8an line just to make sure the volume is fuel is good. On some Mustangs the stock fuel line is only 5/16 and thats a push for 300hp on a Carbed engine. If I were you I would go -8an (1/2 inch) just to leave you some room to grow although -6an line (3/8) would probably do fine.
Tivo304
Aug 28, 2023 12:19 PM
StalkerGT
Sep 25, 2015 02:41 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
