measuring pushrods
The average gearhead doesnt keep a mic that can measure down in the pushrod cup. It's easy to use the right lifter with just a set of checking springs. It's way to easy to do it the right way to make any assumptions in this area. Checking springs are only 2.00 dollars a pair. lol
True this method is easy, but it’s not the only way. And no assumption have to be made, there can be allowances within .050” after measuring.
i took my stock hydraulic roller apart and turned the plunger upside down which effectively made it a solid lifter and measured that way with my stock springs (i also checked with my checking springs and got the same numbers) you can also make your own adjustable pushrods and eliminate the guesswork...
http://mmb.maverick.to/showthread.php?t=31437
o and those checking springs are so flimsy i see why they are lighter than the one in the lifters
Most do have a venire caliper and can measure cup to rim depth.
But the average Gearhead may not have the tools to disassemble the head.
A valve spring compressor is one of those things that the average gearhead needs in his own toolbox or at least have access to one. Either on the car or off. Any time you change cams you need to change springs. If you are building your own engine you have to be willing to invest in the basics.
In most cases .050 allowance is fine sometimes it's not. Thats the reason companies make custom length pushrods.
Bottom line here is if you have invested in a pushrod length checker and are building your own engine a 2 dollar set of checker springs to do the job right where you only have to make one measurement isn't a stretch. You should have had a valve spring compressor befor ever taking on this job. Or at least have access to one.
im not using a reduced base circle cam, i have the retro lifters from comp with the link bars. most who used a reduced base circle cam used the parts out of a newer roller block, or so i have read. thanks for the help guys i have the checking springs and adjustable pushrods. thanks again for all the help
