measuring pushrods
Old Apr 1, 2009 | 05:09 PM
symonds86's Avatar
symonds86
Default measuring pushrods
will a stock roller lifter made solid work for measuring pushrod length if i am gonna run retrofit lifter? if not what do i use? these retrofits arnt cheap so i really hope i dont gatta by one to use
Old Apr 1, 2009 | 07:07 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
yes you can convert a stock lifter for checking purposes
Old Apr 1, 2009 | 07:43 PM
symonds86's Avatar
symonds86
ok i just wanted to know if measuring with a stock lifter that converted will yeild the right length pushrod to use with my retrofit lifters. im using a nonroller block with roller cam
Old Apr 1, 2009 | 07:50 PM
mjr46's Avatar
mjr46
^^^not sure.....but a quick way to check it when you first set them up, do it with both the converted one and retro one and see where the contact patch is on the stem and see if it contacts at the same spot, I color the tips of all stems with a black sharpie and then wiggle the rocker to see where the contact pattern begins
Old Apr 1, 2009 | 07:52 PM
symonds86's Avatar
symonds86
ok good idea
Old Apr 1, 2009 | 08:00 PM
mjr46's Avatar
mjr46
just use the same length push rod or same length on the checker for both set ups to confirm it
Old Apr 1, 2009 | 08:19 PM
symonds86's Avatar
symonds86
ok i will do that i have adjustable pr's and testing springs coming with the heads, since the retros are hydro and not solid they should still give me a close reading if they are correct
Old Apr 1, 2009 | 08:25 PM
mjr46's Avatar
mjr46
the checking springs will make things easy when it comes to checking things, a set came with my summit degree kit and they work well
Old Apr 1, 2009 | 08:41 PM
symonds86's Avatar
symonds86
ok may be a stupid question but i have read a few articles on this subject but never got this ansered. do you check every cylinder? and do you torque the head on then use that tools that allow you to swap springs 'forgot the name' with the heads on to change springs
Old Apr 1, 2009 | 09:56 PM
AdderMk2's Avatar
AdderMk2
Banned
grab your retrofit lifters and measure their height... if they are taller than the stock roller lifters, take the difference between the two, and SUBTRACT it from the push rod length that you get when measuring with a solid-converted hyd-roller lifter
