Took my car to Byron dragway...
ran a 14.50 @ 93...I left the line at like 1200 rpm (25 psi in rears)...I imagine I could have run faster if Id left harder (2.15 60ft)...what do you guys think? See sig for mods...since then I have added new cap, rotor, plugs, wires, coil and bumped the timing to 14*...what times are you guys running with this set up on street tires (Nitto 555 extremes)?
RE: Took my car to Byron dragway...
agreed, my wheels weigh a ton...but I think I still had some traction left...I just didnt want to fry the clutch...would you do subframe connectors or control arms first?
I would do the control arms first....
first I would buy a pad to write down things like track temp, psi in tires ,rpm launch etc....good notes will help....when at the track I would buy 2 old ten holes and some et streets..you see a 1.90 60 foot on just that
not sure because i had an 86 Gt hatchback
3.73 gear
5-speed w/ pro 5.0 shifter
ford racing aluminum driveshaft
mac shortie headers
bbk cold air intake
a/c / smog pump removed
2.5 catless h-pipe w flowmaster 2.5 catack
and a b303 cam
and i ran 13.8's probably becasue it wasent a convert also but im guessing for what you have its ok
3.73 gear
mac shortie headers
bbk cold air intake
and a b303 cam
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
