Need help tuning, car is sputtering...
first thing I'd do on that seeing the pic is set the idle air bleed adjustment screws, to do that you'll need a vaccum gauge and doing one side at a time you screw them in until car starts to die, then back out until highest vaccum setting is reached and as soon as you get that reading I usually go 1/8th a turn out more but not necessary, after idle circuit is set the best way to tune the accelerator pump circuits on holleys are they sell pump cams that are removable and different ones can be put on to change the delivery rate with lazyier or more aggressive ramps for quicker or more initial shot of fuel, also the squirters can be changed to a larger diameter ones to allow a greater discharge of fuel, usually hesitations that appear only on a throttle stomp like you explain, are related to a lean / flat spot, and are cured via accelerator pump tuning, that's to say the float level and FP is all set properly and all tune up parts are good and there are no vaccum leaks, also one thing I have done to cure some hesitations/brief stumbles on performance motors was to bump timing to 13-15 base
Well i had the stang out today and my dad played with the carb a little today...he went half turn leaner on each screw then i would go to 5 in first then get to 10 in second and give it about half throttle, it sputtered once and then pulled, so he did another half turn and it did good again but on the way back to the house i did the same as before but it sputtered pretty bad....any ideas?
Aright, did a little more tuning, and the best spot i found was 2 turns out of where the screws were at when i bought the car..., it still sputtered, but very little, and when it did there was a faint pop, but once it cleared the car pulled like a beast, but the sputtering is not gone, im starting to get annoyed with this.
If i cant figure something out i might have a speed shop take a look at it, which i really dont want to do.
Oh where should the fuel pressure be? It was between 5 1/2 and 6 1/2 psi throughout the day of tuning.... If you need the full list of mods on my car to tell me how it should be tuned i will post them up..
5.5 is a good place to set it at, you need to use a vaccum gauge to set idle bleed screws for accuracy, anyway, if the hesitation occurs on part throttle acceleration as I stated before I'd play with the accelerator pump circuit by either putting larger squirters on or change the delivery rate through pump cam switch to one with an initial quicker ramp on the pump cam
Just got off the phone with the previous owner, he said hes going to come down next weekend probably and help me tune it, he said the squirters in the carb need to be turned down or something, i cant wait untill i can just step on the peddle and just let it GO! haha.
xbmx89
Texas Regional Chapter
Nov 10, 2015 10:43 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
'stangdude
Aug 12, 2015 01:27 PM
