Which Clutch?
Old Jun 19, 2005 | 11:52 PM
1985ford's Avatar
1985ford
Default Which Clutch?
Hi, I own a red 1985 mustang GT, 5 spd, with t-tops and 3.73 gears. Heres my question... The rear main seal is cooked, and soaked the clutch with oil so i am replacing all of the following: rear main seal, clutch, pressure plate, and through out bearing.... and i can't decide on which clutch kit to go with. I was leaning toward the King cobra from ford racing, only because i know that it is a safe bet but i was wondering what preferences other people have.
I use it as a daily driver, but need a strong clutch because i take it to the drag strip often, 2-3 times a week. I call it my driving project because i, just like most of you out there, do modifications as the money is there. I am not concerend with extra pedal effort for daily driving if it is a strong grabing clutch.
thank you all for your help,
Dan
Old Jun 20, 2005 | 12:24 AM
stanglx2002's Avatar
stanglx2002
Default RE: Which Clutch?
i have a Heavy duty Ford Racing Clutch in my car and it works great with my DD and with a stroker motor too
Old Jun 20, 2005 | 12:39 AM
posnick's Avatar
posnick
I just put a centerforce dual friction clutch in mine. the clutch and throw bearing was only $327 canadian. I cant make it slip and ive tryed. good pedal pressure and its quiet too.
Old Jun 20, 2005 | 01:48 AM
CaTalyst.X's Avatar
CaTalyst.X
I would say either the FRPP Heavy Duty Clutch kit or the FRPP King Cobra kit, both will provide plenty of clamping power. I would get the flywheel resurfaced or replaced if i were you also. Personally i like the King Cobra Kit, supposably less pedal effort.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
