Need Help PLZ!!!!!!!!!!!!!!!!!!!!
Old 04-20-2009, 09:57 PM
Cisco 5.0
Cisco 5.0's Avatar
Default Need Help PLZ!!!!!!!!!!!!!!!!!!!!
I have a 94 Mustang with 215K miles. I think my Tranny is going out on me not sure but i think it is. It runs fine sometimes in the morning but later in the after noon like around 5 when i get off of work it runs like its going to die on me. when i press on the gas peddle it feels like the car is misfiring and going to die out. but after a while the car runs like this for a while not going past 30 to 35 miles per hour. I have notice once the check engine light goes on it starts running fine. And just today i was driving it and i couldnt go more than 15mph couldnt go past 1500 rpm and i had to pull over more than once to rev the engine to see if the rpm can get past 1500 it did but for a while and it would do the same thing. Can anyone help me out plz. Thank you
Cisco 5.0 is offline
Old 04-20-2009, 10:26 PM
Nav50
Nav50's Avatar
Run a koer test. Sounds like your timing could be off. You may also have a dead cylinder. Pull the codes and post them up here. Also, if you said it is misfiring, then it is most likely not your transmission.
Nav50 is offline
getnmineinmay
04-06-2005 12:15 PM
supertrooper4
SVT Forums
09-18-2004 03:24 PM
mustang_2004_65
10-21-2003 11:18 PM
Quick Reply: Need Help PLZ!!!!!!!!!!!!!!!!!!!!
