T5 question
i am running a 4banger t5 and i love it. the gearing is way better and the reason its rated less is because of the gearing and even the v8 t5 is under rated for even a stock 5.0 so to answer the question if you have 300hp with torque around 400 you need a geforce t5 rebuild to handle. stock is rated at 260ft lbs or so.... most stock efi 5.0s make 300ft lbs which is why the temporary 5 doesnt last,lol
Yeah, stock V8 t-5 is rated @ 265lb/ft and the cars had 300 stock.
Mine has been drove pretty hard in it's 165K miles and has had nothing but 1 clutch @ 130K, 1 fluid change @ 100K. It has been thru slicks and NOS (on a weekly basis for a long time and was a daily driver) and has never broken. It has been Ford Tough for sure!!!
Yep, it lived a long life!! That's alot of carnage there
Mine is noisy and the syncros are worn. Shifts like a dump truck, but still keeps on trucking.
I'm hoping that this 85 shifts alot smoother. I drove my friends 93 awhile back it it was so smooth, I couldn't believe how easy it shifted. Even with the short Hurst handle. I have to run the stock handle on my Hurst shifter, cause it's hard to shift without the leverage of the longer stick. I have the Hurst Chrome stick, but it isn't shaped right. If I bolt it up with the the splines meshing like they should, 1/3/5 gears are in the dash. I can bolt it on backwards and it is better, but too far forward. I think It have have been boxed wrong. The console plate is 87-93, but I think the stick may be 79-86.
I like the old school stick, but it doesn't fit right.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
