T5 question
Old 04-24-2009, 09:29 AM
83stangglx
83stangglx's Avatar
Default T5 question
What is the difference in a T-5 that is behind a 5.0 mustang originally and one that is behind a 4 banger? Which would be better?
83stangglx is offline
Old 04-24-2009, 10:09 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
torque capacity rating, gear ratio and input diameter for pilot bearing is smaller
mjr46 is offline
Old 04-24-2009, 01:19 PM
83stangglx
83stangglx's Avatar
Which woud i rather have behind a 5.0 with about 300 horse on the crank?
Old 04-24-2009, 01:24 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
something other than a t5
different year t5's have different ratios and tq capacity rating. be specific what year t5 you are referencing.
FivePointOhh is offline
Old 04-26-2009, 12:12 AM
lxman1
lxman1's Avatar
I'm going to hijack this thread. I found a good deal on a low mile T-5 from a 85 5.0 HO Capri. (Same as GT Mustang). Is it worth putting in my 88 LX? Mine could use an overhaul with about 165K on the clock.
I'm pretty sure that the 85 has a 2.95 1st vs my 3.35 and that's ok, I have 3.55's already. I can get motor and trans (carb to tailshaft) for $400. Been in a garage for 10 yrs. Project never got built. I would probably just buy that tranny if it is worth using.
lxman1 is offline
Old 04-26-2009, 12:14 AM
mjr46
mjr46's Avatar
heck, I'd buy the whole set up, not everyday you come across an 85 drivetrain
mjr46 is offline
Old 04-26-2009, 12:19 AM
lxman1
lxman1's Avatar
I was just reading, and it may be a 3.35 1st gear Now I'm confruzed
http://www.moderndriveline.com/Techn...t5_history.htm
Perhaps I should just go C4 with a 2800 stall
lxman1 is offline
Old 04-26-2009, 12:24 AM
mjr46
mjr46's Avatar
this chart will tell all
http://www.therangerstation.com/tech_library/T5ID.htm
mjr46 is offline
Old 04-26-2009, 12:26 AM
lxman1
lxman1's Avatar
Nice list, I found a small version in a car craft article as well
'83-'84 2.95:1 1.94:1 1.34:1 1.00:1 0.72:1 2.76:1*
'85-'89 3.35:1 1.93:1 1.29:1 1.00:1 0.68:1 3.15:1
'89-on 3.35:1 1.99:1 1.33:1 1.00:1 0.68:1 3.15:1
Tremec 500 3.27:1 1.98:1 1.34:1 1.00:1 0.68:1 3.01:1
Tremec 600 2.87:1 1.89:1 1.28:1 1.00:1 0.64:1 2.56:1
Tremec 600 2.87:1 1.89:1 1.28:1 1.00:1 0.82:1** 2.56:1
Looks like the 85 is a direct drop-in.
Thanks.
lxman1 is offline
Old 04-26-2009, 12:32 AM
mjr46
mjr46's Avatar
it is^^^^^^^^^
mjr46 is offline
Quick Reply: T5 question
