surging at idle, need help
Old 04-24-2009, 12:12 PM
86GT 93LX
86GT 93LX's Avatar
Default surging at idle, need help
my car surges at a idle and im not sure why im hearing a wierd sound coming from the drivers side near the valve cover that sound like bad timing or a miss. my tach goes up and down as it surges. i think it might be a intake manifold leak any other things?the miss is almost like a tick sound but more of a exhaust sound
86GT 93LX is offline
Old 04-24-2009, 01:37 PM
86GT 93LX
86GT 93LX's Avatar
heres a few vid clips u cant hear the exhaust real good till the end of this clip
http://www.youtube.com/watch?v=4lauPlJ8zng
Old 04-24-2009, 01:40 PM
86GT 93LX
86GT 93LX's Avatar
and more
http://www.youtube.com/watch?v=p15O4BWpCsk
Old 04-24-2009, 03:56 PM
86whitepony
86whitepony's Avatar
welcome to owning a fox! check for vac leaks, clean your maf, check for codes
86whitepony is offline
Old 04-24-2009, 05:19 PM
AudioNutz
AudioNutz's Avatar
I've seen two other articles that look like they might be useful for this condition:
DIY KOE/KOER self test combo ..... this will help ID'ing what in the EEC could be causing the surge...
http://sbftech.com/index.php/topic,2471.0.html
Base Idle Reset.
http://sbftech.com/index.php/topic,1031.0.html
AudioNutz is offline
Old 04-24-2009, 05:52 PM
86 5.0L
86 5.0L's Avatar
ha! congrats you own a worn out fox
mine does the same thing, of course I have a exhaust leak at the header flange, mid-pipe connectors, vacuum leaks all over the place too
86 5.0L is offline
Old 04-24-2009, 10:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
koer first and if you have an exhaust leak before o/2's , fix that
mjr46 is offline
Old 04-25-2009, 05:39 PM
86GT 93LX
86GT 93LX's Avatar
yea its a exhaust leak, does that cause the o2s to read funny?
i tested my compression 2 times on each cylinder im 150-160psi on all cylinders so that actually good. im waiting to put on my mac equal length shorties so ill get that really thick graphite gasket set stuff. i cleaned the IAC, i seafoamed the brake booster. i will pull the codes. i dont have a cel so its possible.
Old 04-25-2009, 05:49 PM
Sidewayz6.0
Super Moderator
Sidewayz6.0's Avatar
I have to tell you. The best response I've ever seen to a "My Fox is surging" thread, was...."Really? No ****."
LOL...Welcome to a foxbody.
Sidewayz6.0 is offline
Old 04-25-2009, 05:54 PM
86GT 93LX
86GT 93LX's Avatar
Base Idle Reset.
great links the set screw might be my prob plus ill test the tps
Quick Reply: surging at idle, need help
