95 stalling?
95 stalling?
Over winter I installed and edelbrock rpm 2 intake,a bbk cold air, and a flow tech off road x-pipe. I found now when the car is cold
it won't idle and on the odd occasion when it's warm it'll stall as well, anything above idle runs fine. I have verified no vacuum leaks.
Timing is set at 12 bdtc. Any sugestions?
RE: 95 stalling?
hmm well the x-pipe and cold air intake is no problem... so the problem may relay to the upper and lower now if there are no vaccum leaks then it is possible your timing might be off just a smudge or the other may be a sensor or idle air control valve. just my .2 cents
trashxtrash
09-20-2015 10:49 PM
