overheating
Old Jun 24, 2005 | 06:57 PM
yzf426f's Avatar
yzf426f
Default overheating
after putting my H/C/I combo on I cant keep the car cool. I have the stock radiator its the smaller 2 row....but its fairly new i thought it would do the job. I pulled out the thermo hoping it was just that sticking, and ran the car w/ it out for a couple days. It helps but it still gets too hot especially if your in traffic or get stuck at a long light. No symptoms of head gasket failure like I had before, oil looks good and no white smoke. I don't kno where to go from here
Old Jun 24, 2005 | 07:01 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: overheating
timing set right?
clutch fan ok?
full of water?
head gasket on right?
Old Jun 24, 2005 | 07:10 PM
yzf426f's Avatar
yzf426f
I'm running about 12 degrees timing, i'm pretty sure the clutch fan works ok, how do i check it? it is full of coolent
Old Jun 24, 2005 | 07:17 PM
stanglx2002's Avatar
stanglx2002
is the fan spinning
Old Jun 24, 2005 | 07:20 PM
yzf426f's Avatar
yzf426f
yea it spins
Old Jun 24, 2005 | 07:23 PM
stanglx2002
the thermo did you put in and you did fill the radiator with hald radiator fluid and half water right
Old Jun 24, 2005 | 09:43 PM
vfast's Avatar
vfast
I ♥ Acer
first see how easy it is to turn with the engine off ,look for leaks...you do have the fan shoud installed right?
BOB ROME
Jul 26, 2023 01:54 PM
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
