Compression and power adder options
Old May 23, 2009 | 01:09 PM
2broke2gofast's Avatar
2broke2gofast
Default Compression and power adder options
I've got a motor, that I believe to be 10:1 compression. What options do I have if I want to go with a supercharger or turbo. I realize that this isn't a pump fuel friendly combo, so what other routes can I go besides new heads?
Old May 23, 2009 | 07:56 PM
67mustang302's Avatar
67mustang302
Nitrous
Old May 23, 2009 | 09:35 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you'll have to lower compression for s/c or turbo
Old May 24, 2009 | 10:00 AM
08 Bullitt 2310's Avatar
08 Bullitt 2310
Yeah I'm going to second the nitrous if you are careful.I put the nitrous on a 10 to 1 Small block chevrolet once that had aluminum heads and was VERY careful and WOW! What a difference.
You are too far out on compression to either not pull the heads and or pistons to go FI without some problems.
You can bleed off some compression with a cam but then you will be defeating the FI.
jwog666
Dec 27, 2021 08:09 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
logan409
Sep 26, 2015 07:43 PM
Sep 25, 2015 06:58 PM
