Vacuum line replacements
Old May 27, 2009 | 10:09 AM
86 5.0L's Avatar
86 5.0L
Default Vacuum line replacements
ok I got the (soft silicone)lines to replace the hard brittle (nylon?) lines but the tricky thing is how do I replace the rubber boots at each end? also the rubber boots that run from the EGR solenoid(not the valve) to the air valves on the smog pump return line, are they even possible to take off? I had a hard time trying to remove them.
Old May 27, 2009 | 10:36 AM
NotchAbove's Avatar
NotchAbove
Here is what you do, for the boots at the end, you need to cut the hard plastic leaving enough to slip the new hose on. (Or you could just eliminate the boot all together).
Also there is that 4 port cluster near the passanger side (one of those lines goes to the EGR, Manifold, and 2 to the smog stuff). You can remove the plug and you will see you can push hoses right onto the yellow plastic part.
Hope this makes sense.
Old May 27, 2009 | 01:17 PM
86 5.0L's Avatar
86 5.0L
the problem is there is BARELY enough old line to keep the new hose on, I ended up supergluing the hose on to the last .5 mm of old line, making sure not to get it inside the airway
that is the EGR solenoid, I cant get the boot off from the one that goes to the smog valves, again I just ended up super gluing the silicone hose on the few MM that where left
Old May 27, 2009 | 01:35 PM
NotchAbove's Avatar
NotchAbove
I see what you mean. Like I said, you can scrap the boots. But it looks like you got it going. Cool.
Old May 27, 2009 | 07:39 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
just plug vaccum line directly into the component, no need to try and save a faulty end
Old May 28, 2009 | 01:08 AM
86 5.0L's Avatar
86 5.0L
the thing is, the boot on the EGR solenoid wont come off, and is hardwired with another vacuum line, its a pretty messy
Old May 28, 2009 | 09:22 AM
NotchAbove's Avatar
NotchAbove
Photos ?
Old May 28, 2009 | 09:47 AM
smacked1's Avatar
smacked1
yeah take some pictures im going to be doing the same thing since one of my lines broke in half going to the first component/closest to the front of the car, i just used to small hose about a foot long and slipped both ends in to meet
5.0muscle
Jan 11, 2016 01:17 PM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Art161
Sep 9, 2015 10:33 AM
Sep 8, 2015 11:50 AM
