Oil Pressure
normally the rule of thumb for engine builders is to get 10psi of pressure per 1000 rpm at load/normal operational temp (212F normally). If you are running the right oil for your motor (not always what the manual calls for) if you are getting anything from 8-15psi per 1krpms i would not worry about it. Also make sure your oil gauge is working right.
40-60 psi at 2k rpm is the ford spec at opperating temp (190-210 F) with specified oil grade.
The 10 psi per 1000 rpm rule no longer applies in today's world of engines, thats old school muscle car verbage.
ccdguy
09-19-2015 05:20 PM
