Rear end??.....
Old 06-10-2009, 09:43 AM
smacked1
smacked1's Avatar
i have 3.55's and they are great, i actually might want to go 3.73 later on
smacked1 is offline
Old 06-10-2009, 09:53 AM
302army187
302army187's Avatar
Originally Posted by r1sky5.0
Yup planning on getting 3.55's with my aod tranny. Are these gears good because this is my daily driver and I have been told that they cause the car to over heat?
depend's on your goals. If you just want a little more up and go, then 3.55's or 3.73's are great, id get the 3.73's.
i daily drove my car with a AOD and the 4.10's for a long time. 4.10's are not as bad as some people make them out to be.
302army187 is offline
Old 06-10-2009, 10:58 AM
306stang
306stang's Avatar
I put 3.27's on my AOD and the difference is about 10mph for every shift. I didnt put on a higher ratio because that's the highest ratio they produced AOD's with so I figured the engineers at Ford had a reason for it.
So instead of going into OD @ 55mph its @ 45mph
I'm guessing 3.55's will put you around a 13 mph difference. (Not sure)
Its got some more pep around the road, I lost some noticable MPG but that could also be because I'm on the gas a little more now.
306stang is offline
Old 06-10-2009, 03:03 PM
302army187
302army187's Avatar
i got better MPG in the city and worse on the highway with the 4.10's. take's WAY less throttle to get the car up and moving.
Old 06-10-2009, 06:41 PM
5.0's Avatar
I wouldn't see em making your car overheat, may make your trans work alittle harder not sure. If you like to drive your auto hard alot i'd suggest a dedicated trans cooler, it'd be a good idea even if you don't.
5.0 is offline
Old 06-10-2009, 11:08 PM
calfroper_06
calfroper_06's Avatar
^^^^^hes right, heats what kills a tranny, and if your cars coolingsystems working correct you should have no overheating problem
calfroper_06 is offline
mtgldr
02-03-2024 09:00 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
Quick Reply: Rear end??.....
