soo much money no fix
ok guy i was told that ill need a new ignition controlle module due to my engine shuting off randomly and sometimes not turing back on for a while. i did a hell of a tune up in the 5.o new belt,tentionor,starter,altinator,plug wires with and plugs, disributor. ingnition controller, coil and still the engine cuts out randomly, now i read some were that my95 gt has two FP is this true? the pump was tested at a local mustang shop were i live and they said its working as it should. and when i was told to check myself with a small srew driver and press down on the valve it squirts out gas as it should, IDK. I LIKE THE CAR AND ITS MY SECOND OWN CAR AND IM IN LOVE WITH IT SO I DONT WANT TO HATE IT. ppl plz help me out. i spent so much on tows and repairs and so far it got me no were
well do yourself a favor and buy a manual. start by picking up a code scanner or get it scanned at a shop. if there are no trouble codes, more than likely it is the TFI module on the distributor.
Thick Film Ignition system used on 5.0 mustangs tend to overheat and go bad. So once the car is warm, it will begin to lose connection and cut-out, not allowing the car to restart untill it has cooled down.
the tfi is what i ment by the ignition controller, well anyways that is a new one and thats the first thing i cheack when the engine cut off and its like someones touch. and even if i start the car for the first time that day ill take two tries to start some cases 10min to start so im lost
someone told me about that on here and the shop had a gauge they used,
bradleyb
11-27-2015 07:50 PM
