horn pad
I would think you could use any thin foam like laminate floor foam or something along those lines. What I did was use the little round foam circle you get in cd spindles and put it around the large contact in the middle along with the old foam and it works fine. The foam fix applies only if your horn sounds whenever the pad is plugged in otherwise you are looking at another problem.
mungodrums
Suspension
02-09-2016 09:05 AM
Ghost_Conscience
09-23-2015 02:17 PM
mungodrums
Suspension
09-07-2015 07:22 PM
