Brake Problem
Brake Problem
I got a 86 mustang that I just bought and the brakes are really soft. I tried bleeding the brakes but no fluid came out of the passanger rear bleed valve or the front drivers bleed valve. Fluid is getting to the lines and when I pull the lines off and pump the brakes fluid is getting pumped through. Could the problem be that the brake cyclinders are bad?
mungodrums
10-07-2015 04:01 AM
musnicki
09-23-2015 07:11 AM
