stall problem
Old Jun 25, 2009 | 07:26 PM
NoGo95GT's Avatar
NoGo95GT
Considering the car runs worse after it warms up, makes me positive it's the dizzy. Here's a good read for you on the stator/Hall Efffects Sensor inside the distributor:http://www.wellsmfgcorp.com/pdf/Counterpoint3_1.pdf
Also, it might be a good time to clean your MAF as well.
Old Jun 25, 2009 | 08:42 PM
malo012000's Avatar
malo012000
thanks again that was good info
Old Jun 25, 2009 | 10:08 PM
panzerbefehlswagen's Avatar
panzerbefehlswagen
I am now joining forces with you malo! Since I have a 94gt with the same EMBARRASING! issue, Nothing quite like waxing and detailing your stang up to have it die right after the dude at the emmissions place was commenting on how nice my car was etc,.
I am going to run my TFI sensor down to Advance this weekend. If thats not it I'm thinking its MSD time probly get a new coil and those red msd wires to pimp it out. Man I hope that fixes this ****.
Is this a 94/95 issue only cause I haven't seen any foxes commenting on the issue, if it is a 94/95 issue what makes our cars different from the foxes as far as dizzys and sensors? I didnt think that our engines were much different except for the intake and the elec fan.
Old Jun 25, 2009 | 11:26 PM
NoGo95GT's Avatar
NoGo95GT
I would keep your stock coil. Chances are, it's not bad. Do what you said you were going to do with the TFI module. If that's not the case, then chances are, it is your dizzy as well. From what I have seen, the Fox's do have the same problem. However, I've seen more cases with them having a bad TFI module. As for our motors being the same, there are actually several differences. Our motor is NOT a Fox motor, but a Thunderbird motor. However, it does not use a Thunderbird cam, nor a Mustang cam. That's why there are no beans past 4500rpm( I understand a Fox body runs out of power here too, but the SN-95 is much more lethargic). Add 200 pounds + a conservative tune, and our cars will get waxed by a properly maintained Fox any day. Anyway, that's my .02 on our motors.
Old Jun 26, 2009 | 07:59 PM
muhstang1's Avatar
muhstang1
Default New Dizzy
I am looking at buying a new dizzy too. Where does a guy get the quality replacement without spending $250? Besides Ebay of course. I understand rebuilts are a no-no as lots of people report probs with them.
Old Jun 26, 2009 | 10:40 PM
Black SunShine04's Avatar
Black SunShine04
Wow I just posted on this same issue and didn't see this,it is a crazy problem that I want to fix before it happens again. It wouldn't rev over 1 grand but then out of the blue it cleared out enough I could drive it into the parking lot.
Old Jun 26, 2009 | 11:11 PM
muhstang1's Avatar
muhstang1
http://fordfuelinjection.com/?p=12
Here is a test you can run to test your TFI and stator operation. Page 3 under TFI Tester, the last sentence or two.
"A better test is to check the fuel pump relay while cranking the starter. Not the 2 second prime after the key is turned on, but while cranking the engine. If the fuel pump kicks on when cranking, the TFI module and Stator are good."
I have not tried it yet, tomorrow I guess. Of course you have to run this test when you have a no-start situation.
It's worth a shot anyway.
Old Jun 26, 2009 | 11:22 PM
NoGo95GT's Avatar
NoGo95GT
Remanufactured ones from Autozone and Oreily's and Napa work well and won't break the bank. Yes, you can have problems with them. However, they usually carry lifetime warranties so you can take them back for a replacement(Out of four I've had, I've had one bad one). BTW, many new ones have complications as well.
Old Jun 26, 2009 | 11:23 PM
NoGo95GT's Avatar
NoGo95GT
You could have a bad TFI module, fuel pump or stator/Hall Effects sensor in the dizzy. You can have the TFI module tested for free at Autozone or any local parts store. Nice info Muhstang, especially for beginners just getting into the Mustang world.
Old Jun 26, 2009 | 11:41 PM
Black SunShine04
http://www.autosafety.org/stalling-f...e-class-action
