Parasitic drain somewhere HELP
So the day before im selling my car i find a major parasitic draw on the battery of 8.7 amps which is HUGE. Did a parasitic draw test and yanked every fuse and yanked the ignition harness and Im still getting a huge draw on it. Now when i detach the fusible links under the hook the drain goes away. The large gauge green wire and the yellow wire which splits to 4 other fusible links. Something under the hood is causing this drain. I have a new alternator and new starter solenoid so i ruled those out. What else can i check???
don't be so sure on the alt just cause it's new, pull the charge wire/ unplug the connector to it and see what happens, also if you have any aftermarket stuff wired in such as a huge stereo unplug that stuff while watching the dvom
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
