ac not working right
Old Jul 26, 2009 | 04:51 PM
samsonhusky's Avatar
samsonhusky
Default ac not working right
I have a 90 gt that the ac will stop working on sometimes. When it stops working it is after I have been driving around for awhile the compressor kicks off when this happens. Then it may work again with out even killing the car just turning of the ac for awhile, and it's always worked if I kill the car and let sit for 20 mins or so. Other days I may have no trouble at all. The compressor sounds good when it's running. What should be some of the things I need to check for.
Old Jul 26, 2009 | 04:54 PM
Liquid_02's Avatar
Liquid_02
If you have an electric fan make sure it's wired to the A/C circuit, and check to see if the condenser is plugged. Other than that put some gauges on it to see what's happening.
Old Jul 26, 2009 | 05:07 PM
mustangsneverdie's Avatar
mustangsneverdie
your comp. clutch could be going out or it just might need to be recharged
Old Jul 26, 2009 | 09:53 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you need to see what the pressures are doing = need gauges hooked up
1TUFF302
Nov 5, 2015 04:02 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
